I'm replacing some parts in my atv. These parts are what makes it shift and are in the "sump" area.
I will need to use something on them during assembly and to prevent wear untill the oil gets splashed onto them.
The bike calls for jaso-ma oil. What can I use that won't have any negative effects on the wetclutch?
I have 2 kinds of assembly lube. One is a black greasy stuff that it loaded with Moly. The other is "Torco" engine assembly lube.
Would regular oil be ok to use or something else?
