Lab: Schaeffer's Specialized Lubricants
Engine: 739cc air/oil-cooled four-stroke four-cylinder motorcycle engine with combined transmission and wet clutch.
Miles on engine: 27,154
Miles on oil sample: 3000
Miles on oil filter: 3000
Oil: Texaco Havoline 20W-50 (Current API SL formulation).
Make-up oil added: Approx 5% of total crankcase volume.
Operating conditions: 65F to 100F, mixed high and low speed/RPM, no short trips, moderate idle time
Engine condition/tune: Good overall. Mild knock at startup. Factory jetting, pilot screws 3 turns out (overrich idle). Modified exhaust and airbox, stock air filter element.
Results from previous 3k mile analysis of Delvac 1300 Super 15W-40 are in "()"
Results from previous 3k mile analysis of Rotella T Synthetic 5W-40 are in "[]"
Copper: 1ppm [2ppm] (2ppm)
Iron: 12ppm [10ppm] (16ppm)
Chromium: 0ppm [0ppm] (0ppm)
Aluminum: 4ppm [3ppm] (6ppm)
Lead: 0ppm [1ppm] (1ppm)
Moly: 3ppm [3ppm] (71ppm)
Phosphorus: 832ppm [976ppm] (1769ppm)
Zinc: 1005ppm [972ppm] (1852ppm)
Magnesium: 48ppm [220ppm] (757ppm)
Calcium: 2339ppm [2950ppm] (4071ppm)
Anti-freeze: 0% [0%] (0%)
Fuel Dilution: none [none] (none)
H2O: 0% [0%] (0%)
Silicon: 3ppm [2ppm] (3ppm)
Viscosity: 15.34cSt@100C [13.94cSt@100C] (13.67cSt@100C)
Mfr viscosity spec: 19.0cSt@100C [14.6cSt@100C] (15.5cSt@100C)
Oxidation: 1% [0%] (9%)
Nitration: 0% [0%] (2%)
TBN: Not tested.
Soot: Not tested.
H2O: 0% [0%] (0%)
TBN: Not tested.
Soot: Not tested.
