How often or how many miles do you guys run your 15w-50 in your bikes? i use it in my honda 929 sportbike
I use it and plan to run it for 5k to 10k miles in my modified Magna depending on how long it lasts. Still waiting for the first UOA results.quote:
I finally posted that UOA on 15w50 red cap in my '99 Magna. At 3000 miles it looked pretty good, TBN still > 10 with little to no viscosity shear. I'm still running this oil.quote:
I sure hope so. For the price it should work twice as well!quote:
I put in the mobil 1 mx4t stuff, i hope this stuff works as good as the 15w-50.
FYI I ran Delo 400 for about 1500 miles when it started shifting bad, was not compatible with the engine/trans in this bike.quote:
Originally posted by Chris:
When it starts shifting poorly you will know it is done.
