I disagree with this statement. I have used ATF in 2 stroke gear boxes with wet clutches many times since the early 80s. Because of good clutch action over 80wt gear oils. And Auto car trannys sure don't have any wet clutch problems with 5w 20 wt. ATF.quote:
Originally posted by JonS:
He also said the thicker oil would make my clutch react better. ????
The thicker oil will exacerbate the potential problem by making the engine run even hotter. But the thicker oil might withstand the heat better.quote:
Anyone ever use 20w-50 in an inline air cooled engine? Or is the 20w-50 only for v twins? Is it to thick for the inlines?
I had many cars and bikes, but the one I consider "The Love of My Life" was a CB 400F Super Sport. 1977 model, if I recall correctly. For those who're not familiar with it, it is an air-cooled inline-4. The ONLY oil I ever used in it was Castrol GTX 20w-50. More or less, it was also 20w-50 for all my other bikes, except for rare extreme-usage applications when I had to use HD-30 Castrol. But the other bikes are not so important.......... the CB 400 Super Sport is. If 20w-50 is good enough for the CB 400 F, it is good enough for every vehicle made.quote:
