Lab: Schaeffer's Specialized Lubricants
Engine: 739cc air/oil-cooled four-stroke four-cylinder motorcycle engine with combined transmission and wet clutch.
Miles on engine: 24,100
Miles on oil sample: 3000
Miles on oil filter: 3000
Oil: Shell Rotella T Synthetic [group III] 5W-40 (Current API SL/CH-4 formulation)
Make-up oil added: Approx 5% of total crankcase volume.
Operating conditions: 55F to 100F, mixed high and low speed/RPM, no short trips, moderate idle time
Engine condition/tune: Good overall. Mild knock at startup. Factory jetting, pilot screws 3 turns out (overrich idle). Modified exhaust and airbox, stock air filter element.
Results from previous 3k mile analysis of Delvac 1300 Super 15W-40 are in "()"
Copper: 2ppm (2ppm)
Iron: 10ppm (16ppm)
Chromium: 0ppm (0ppm)
Aluminum: 3ppm (6ppm)
Lead: 1ppm (1ppm)
Moly: 3ppm (71ppm)
Phosphorus: 976ppm (1769ppm)
Zinc: 972ppm (1852ppm)
Magnesium: 220ppm (757ppm)
Calcium: 2950ppm (4071ppm)
Anti-freeze: 0% (0%)
Fuel Dilution: none (none)
H2O: 0% (0%)
Silicon: 2ppm (3ppm)
Viscosity: 13.94cSt @ 100C (13.67cSt @ 100C)
Mfr viscosity spec: 14.6cSt @ 100C (15.5cSt @100C)
Oxidation: 0% (9%)
Nitration: 0% (2%)
TBN: Not tested.
Soot: Not tested.
Copper: 2ppm (2ppm)
Iron: 10ppm (16ppm)
Lead: 1ppm (1ppm)
Moly: 3ppm (71ppm)
H2O: 0% (0%)
Oxidation: 0% (9%)
Nitration: 0% (2%)
TBN: Not tested.
Soot: Not tested.
