Finally talked my Dad out of this. He has a 1980 GS1000G Suzuki, air cooled, shaft drive, 5 speed, DOHC, that I used to drive when I was going to college. He drove it some but since he's gotten cancer, it has sit for a long time. He finally told me to come get it. It needs some love. I'm planning to strip it and paint it and "fix" it up. Keeping all things stock though. My question, it has been sitting for about a good 10 years now. Gas tank has rust inside, so I'll have to line it with that gas tank coating stuff that worked really well on my moped that, ironically I got from Dad and it too had sit for about 12 years. What do I need to do now to get it back running. I've heard the old story of adding kerosene or diesel fuel in the crankcase and pour it through the spark plugs and let it soak for a while. I don't even know if the engine will turn over once I get a new battery for it. So, I am open to suggestions. I never did change the oil in it, I don't even know where the oil filter is. Rear gear, drain the fluid or you think it may be OK because it's been sealed all these years? It doesn't leak or anything.
[ June 26, 2003, 09:54 AM: Message edited by: Schmoe ]
