I found this on the Spectro web site. Thought you Triumph owners might be interested.
"Triumph recommends a full synthetic for a specific reason. They had early problems with their engines, mainly the 1100 and 1200 longer stroke motors, galling the wrist pins in the pistons and making piston removal at rebuild time difficult. This was traced to riders ignoring the recommendation to use 10w40 or 15w40 and using 20w50 instead combined with too little warming up time. (and some high speed autobahn riding with a cold engine) These wrist pins are not pressure lubed and would not get enough oil initially. Yamaha had the same problems with their 1200 motors too, it seems to be related to longer strokes with more wrist pin rotation. The synthetics penetrate better into this tight fit area and solve the problem, especially the 15w40 and 5w40 fully synthetic oils, hence the Triumph recommendation for 15w40 full synthetic in all high performance large bore engines and 10w40 part synthetic in all others. Yamaha even went to the recommendation of 5w40 full synthetic oils for their 1000’s in Europe to address this same problem."
