pinoy99, I really like your choices ... but Hondas (their clutches) are supposed to be molybdenum intolerant (especially the newer ones). Both those oils have moly ... especially the Long Life 15W40 which has twice as much as the rest of the Pennzoil lineup.
So, if you encounter any clutch-slippage problems (or possibly even hard shifting), I'd dump it ASAP.
Castrol, Mobil and now even Valvoline are including some (50-80ppm) moly in their formulas.
If you want to play it safe, you could go with Chevron Supreme 10W40 or the tougher Chevron Delo 400 in 15W40. Recently tested samples of these oils show them to produce very low wear numbers in autos and neither has any moly.
Just be sure to keep the drain intervals of these oils VERY short, I wouldn't go over 2,000-2,5000 miles on any of them, especially a motor oil with no moly. Remember, these weren't designed to put up with the byproducts of combustion AND deal with the shear stress of a bikes gearbox.
All the oils you are looking at are no more than $2 per quart so frequent changes are fairly cheap.
Bror Jace
