TCW3 used in racing bike 75:1
I find it very interesting alright. A couple things jump out at me from looking at the pics. The piston has blow by charachteristic of worn rings. The ring land area has deposits indicative of useing a tcw3 ashless formulation in a application requiring a iso egd type fluid. The power valves of high levels of deposits compared to other oils I have seen. the head is clean, but probaly because the jetting is too rich. Had the bike been ran an the proper oil many of these conditions might not be present. The owner also must have sucked some dirt at some point as the piston shows verticle scratches.
quote:
Originally posted by ben walker:
The piston has blow by charachteristic of worn rings. The ring land area has deposits indicative of useing a tcw3 ashless formulation in a application requiring a iso egd type fluid. The power valves of high levels of deposits compared to other oils I have seen. the head is clean, but probaly because the jetting is too rich. The owner also must have sucked some dirt at some point as the piston shows verticle scratches.
Well, considering he's got a total of a little over 100 total hrs ,(we didn't account for playing around prior to racing it) on this engine since new, most of it running the power band between 7 to 13,000 rpm's in actual sand tracks which you can expect to pickup sand unlike most up north run clay tracks. It's had a pretty hard life and around this area with this kind of torture, those are exceptional looking components.
There is no carbon "build up" around the rings as you suggest, it is a discolored area and yes, probably due to the ring wear, but no area has any carbon deposits as you think probably due to the fact it is hard to tell with the pictures. The power valve's, like the top of the piston, have a light soot covering them.
If you have seen better looking power valves and engine wear for the hours and power produced by this engine, I'd really like to see the pics of what you have.
From all the bikes I have seen, most are extremely built up with high levels of hard carbon deposits most of which would take a wire wheel to take off.
I would have not run it 75:1 myself as I am one to stay with what manufactures suggest but thought it still interesting to see how this looked with all it had on it compared to most others that are repaired.
???? You saying your iso egd (I suspect amsoil) is not ashless????
It happens that if you look at the tech data sheet it is recommended for this application.
  • Moly Supreme 2-Cycle Oil meets and exceeds the NMMA TC-W3 category and is recommended for use in all types of water cooled and air cooled two-cycle engines.
  • Moly Supreme 2-Cycle Oil is pre-diluted for easy and fast mixing at all temperatures. It is well suited for use in gasoline and pre-mix engines and oil injected engines in all climates.
  • Moly Supreme 2-Cycle is recommended for use at all manufacturers’ prescribed fuel/oil ratios. Follow the manufacturer’s blend recommendations for the particular make and model of equipment.
Bob,
The ISO EGD spec is an additional requirement above and beyond TC-W3. I believe it has to do with measuring the exhaust emissions, but it's been a while since I read up on it. Using an ashless dispersant is a given in this type of application. I don't think that's an issue at all ....
I would agree that something like the ester based Redline, two stroke racing oils will burn much cleaner.
The iso egd is not a ashless formulation. It is currently the most stringent cert in the world in terms of high temp cleanliness and scuff resistance. It is light years ahead of tcw3.
Ted, the iso cert does have a low smoke test, but it is not emmisions driven as you suggest.
I have a 02 cr500 af with about 75 hours on it useing a iso egd oil. I just replaced the piston and rings. It did not have any of the signs of blowby that the your pics had. The piston skirts as well as the head, exhaust port where clean and the motor still had comp within 20% of stock. The motor had the original plug in it and was run on a 32:1 ratio. We have lots of sand in MI also and I have no scratches on my piston. The schaefers oil my be great stuff in its intended application, but a high output bike is not it.
WATER-COOLED vs AIR-COOLED LUBRICANT REQUIREMENTS
Background:
The types of performance required of any two-cycle engine oil (Table 1) has not changed over time; only the degree of anti-seizure performance, piston cleanliness, smoking, etc. New generations of two-cycle oils are designed to satisfy higher demands presented by newer high-output engines.
The choice of oil for the American two-cycle engines has been largely controlled by marketplace availability. In the 1960's motorcycle engine oils were used with great success. The introduction of injectors in outboards, lighter two-cycle oils were needed for fluidity and BIA (now the NMMA) TC-W® oils were introduced.
Table 1 - Required Performance of Two-Cycle Engine Oils
Provide excellent lubricity. Reduce wear on rings and cylinders. Prevent piston seizures. Provide appropriate lubrication to engine bearings.
Prevent fouling or preignition of spark plugs.
Burn cleanly without leaving deposits in the combustion chamber, exhaust port, or other parts of the exhaust system.
Leave little dirt on pistons. Keep varnish and deposits from forming and keep piston rings free.
Make little exhaust smoke and odor.
Possess anti-corrosion and anti-rust properties.
Mix easily with fuel.
Have good flow properties.
The two-cycle motorcycle engine disappeared from the American scene in the late 1970's due to governmental exhaust regulations. The demand for better air-cooled lubricants in turn slowed with this loss. This left the outboard motor as the primary American two-cycle engine.
Outboard growth was dramatic in the 1980's and with it went most lubricant research. But, the explosive demand for small lawn and garden two-cycle engines, and the resurgence of the snowmobile industry, in the mid to late 1980's, required a reassessment of lubricants for air-cooled two-cycle applications.
The frequency of carbon buildup often is determined by the quality of the local fuel supply, the particular characteristics of the engine and how the engine is used. Motors that run under heavy load are more prone to carbon deposits.
"Three of the four major outboard manufacturers (Suzuki is the exception) have acknowledged at least a few engine failures traced to carbon buildup in the past two years, a situation they blame on a combination of poor-quality gasoline and suspect outboard lubricants." ("Save Your Outboard's Life", Charles Plueddeman, Boating Magazine).
Unfortunately, it's all but impossible for a boat owner to detect carbon problems before engine failure is imminent. According to Yamaha, you may notice that your outboard becomes hard to start or spins unevenly while starting if the ring land becomes contaminated. Once the rings sticks in the ring land, however, it cannot hold a film of oil on the cylinder and scuffing will occur.Two-cycle formula selection must be based on maximum cylinder temperatures. Outboard two-cycle engines have very effective cooling systems, using low temperature lake or sea water, that keep ring belt temperatures between 100-275F. Organic ashless dispersant, based on nitrogen, provide engine protection to 300F. This additive technology also insures clean burning, which is of paramount importance in outboards due to their preignition sensitivity.
Water cooling reduces the cylinder wall temperature and makes piston seizure less likely than in air-cooled engines. This makes possible higher engine speeds. In an air-cooled unit, engine speed at maximum output ranges from 5,000 to 7,000 RPM. Water-cooling allows maximum engine speeds from 7,000 to 10,000 RPM. This trend toward faster speeds and higher output is expected to continue, with oil film formation an extremely important factor in wear control.
With the introduction of unleaded gasolines back in 1985, problems not apparent in the old days began to appear. In four-stroke automotive engines, valve recession, intake valve deposits, and injector nozzle clogging took place creating the need for new additives. In two-stroke outboards piston ring sticking and piston scuffing escalated. It has also been found that some of the commercial unleaded gasolines contributed more to carbon deposits than others. In its mild form, piston rings were cold stuck in the ring grooves. This caused hard starting and rough idle due to a loss in compression pressure. In its severe form, the rings were hot stuck in the ring grooves. This caused poor engine performance from the loss of combustion pressure and shortened engine life from piston scuffing.
Air-cooled engines such as: chain saws, weed cutters, snow blowers, leaf blowers, and most other pieces of air-cooled portable power equipment, are run in short bursts at varying speeds. In these applications, heat dissipates during periods of idle. Reduced engine life due to extremely high ring belt temperatures using water-cooled, low temperature, TC-W® type fluids; are often reported.
In addition, engine builders continue their never-ending quest to increase an engine's power density or specific power (output per cubic inch displacement.) During motorcross races, using the latest high-output technology in both motorcycle and snowmobile engines, race teams experienced reduced power output, especially toward the end of the race. After significant research, this loss of power has been generally attributed to increased cylinder temperatures, caused by greater power density output, and increased RPM's.
To reduce cylinder temperatures, a water jacket system was installed in these high-performance motorcycles and snowmobile engines. This allowed builders to increase RPM speeds by 30%. This increase in RPM's in-itself resulted in a significant increase of specific power output, while the water jacket keeps cylinders under critical temperature levels. This water jacket system soon found its way into the general marketplace, and spurred current sales promotions of high-output engines, especially in the snowmobile industry.
It must be noted that, although these water jacket systems may reduce engine cylinder temperatures under low operating conditions, they were specifically designed to control peak cylinder temperatures at these new higher output RPM's, and are usually found only in the highest output engines. In air-cooled two-cycle engines, cylinder temperatures average 300-350F. Normal exhaust port temperatures range from 1,200 to 1,600F. Some high output small engines have seen exhaust port temperatures measured as high as 2,000F. Ashless dispersant, typical of TC-W® type fluid formulas, are not thermally stable at these ring belt temperatures.
No matter what the marketing claims are, there is significant evidence that even the best TC-W3® formulas are marginal, at best, for extreme temperature/output air-cooled two-cycle engine applications. This conclusion is supported by the major two-cycle additive companies.
Industry studies indicate that the high temperatures encountered by air-cooled engines make them susceptible to premature failure when using oil designed for low temperature, water-cooled outboard engines. As a result of high temperature wear in air-cooled engines, increasing numbers of engine manufacturers are prohibiting the use of all TC-W® type oils. For example, Bombardier specifically prohibits the use of any NMMA TC-W, TC-WII OR TC-W3® outboard motor oils or other ashless 2 stroke-cycle oils in SEA-DOO® watercraft, Sea-Doo® JET BOATS and SKI-DOO® products. In addition, most chainsaw manufacturers worldwide specifically prohibit the use of TC-W® type outboard oils.
These manufacturers demand oils that contain a low-ash, natural metallic detergent, delivering much higher temperature engine cleanup and cylinder scuffing protection. Something that TC-W3® ashless oils cannot provide. Thermally stable, deposit wear control metal-organic compounds are needed for these extreme conditions. In addition, replacing bright stock base oils with a specially balanced combination of polyisobutylene dramatically increases piston scuffing protection as-well-as reducing carbon deposits and exhaust smoke. For more infomation regarding polyisobutylene in two-cycle oil see BP Chemicals PIB Applications.
But, this metallic component is simply not designed for use in water-cooled engines. The water-cooled engines in boats, are run at constant speeds for extended periods of time. As a result, the metal particles in a low-ash oil can heat to the "glow point" as the engine reaches extreme temperatures. The oil's fuel component could preignite and cause engine knock and piston burns. So, in most of these applications, ashless oil is the correct choice.
TWO-CYCLE GASOLINE ENGINE LUBRICANT CLASSIFICATIONS
Water-Cooled Outboard Engines
America has experienced a rapid change in two-cycle oils since 1960. The first ashless additives for outboards were introduced in the early 1960's. By 1970 the Boating Industry Association (BIA) defined the first technical requirements for an outboard motor oil, calling approved products TC-W®.
In 1980 lube injection was introduced for outboards and became widespread by 1984 necessitating a lubricant upgrade. In 1988 the National Marine Manufacturers Association (NMMA), formerly the BIA, issued TC-WII lubricant requirements. This change was a minor change from TC-W® requirements and was specifically aimed at the Variable Rate Oiling (VRO's) injector fluidity problems.
Testing criteria for TC-WII® did not account for numerous field problems reported using NMMA TC-WII® approved fluids. Although not all TC-WII® oils experienced trouble, a new TC-W3® specification was quickly established in April 1993, and included additional tests to eliminate these problems. This category insures greater protection against high temperature wear, gelling problems and the adverse affects of common, low grade "pipeline" gasoline. NMMA TC-W3® is now required for all outboard engines.
When a outboard oil has been tested and meets all of NMMA's requirements, a license is granted. The license permits the manufacturer to display the NMMA symbol on its product with the designation TC-W3®. The marketer's license, a six digit number starting with 3 or R, is also displayed on the container. An owner's manual will tell you to look for oils with the NMMA symbol. The warranty statement in the manual is the only warranty which is official and a mechanic or dealer has no authority to supersede this statement. Federal Law Prohibits dealers/mechanics to require the use of and OEM or specific brand of oil unless the dealer/mechanic can prove to the Federal Trade Commission (FTC) that, (1) no one else has an oil which will work, or (2) they must provide the oil to you free of charge for the required warranty period. See Magnuson-Moss Warranty Improvement Act.
Air-Cooled Land Based Engines
In 1988 the American Petroleum Institute (API) and the Society of Automotive Engineers (SAE) defined oil designations for different two-cycle engine oil applications. These included:
API TA - Asian Use, High Ash Oil
API TB - European Use, Medium Ash Oil
API TC - North American Use, Low Ash Air-Cooled Engine Oil
API TD - North American Use, Ash-Free Outboard, Water-Cooled Engine Oil.
Fluidity of the lubricant was defined by SAE under the following system:
SAE 1 - For high ambient temperature areas (African, Arabian, Asian tropics)
SAE 2 - For moderate to high ambient temperatures (southern US and Europe)
SAE 3 - For moderate to low ambient temperatures and water-cooled injector engines (northern US and Canada)
SAE 4 - Lowest ambient temperatures (Arctic conditions).
Unfortunately, for those who may have depended on this classification system to clarify two-cycle engine recommendations - it no longer exist. API canceled the system in 1993, deferring to the European ISO system and/or Japanese JASO system. Although there is no official two-cycle API classification, oil marketers continue to use the outdated test criteria establish for API TC to qualify air-cooled oils. They also use the SAE numbering system to define fluidity of their product.
These two new International designations for two-cycle engines have been adopted worldwide to classify high temperature air-cooled 2-cycle engine oils. From Europe the ISO "Global" system, and from Japan the JASO system.
ISO "Global" System
Global "GD" is internationally recognized as the highest quality air-cooled 2-cycle oil available. It is a synthetic or semi-synthetic, extreme temperature/anti-scuff/lubricity, low smoke, low ash oil. There is no comparable JASO or API product.
Global "GC" is equivalent to JASO "FC," Japan's highest quality 2-cycle oil. In Japan these oils may also be referred to as "Genuine" oils. These oils are high lubricity/detergent, low smoke, semi-synthetic, low ash oils.
Global "GB" Europe's lowest quality 2-cycle oil, is equivalent to JASO "FB." It is generally accepted that North America's API TC rated oils are equivalent to these oils. These oils do not require any synthetic to meet specifications, but do have detergent and/or lubricity additives, and are typically low to medium ash oils.
JASO System
JASO "FA" rated oils are used in Pacific Rim countries and are the lowest rated Japanese 2-cycle oils. They are medium to high ash mineral oils with limited lubricity or detergency.
JASO "FB" is equivalent to Global "GB." It is generally accepted that North America's API TC rated oils are equivalent to these oils. These oils do not require any synthetic to meet specifications, but do have detergent and/or lubricity additives, and are typically low to medium ash oils.
JASO "FC" is equivalent to Global "GC," Europe's medium quality 2-cycle oil. In Japan these oils may also be referred to as "Genuine" oils. These oils are high lubricity/detergent, low smoke, semi-synthetic, low ash oils.
SUMMARY
After all is said and done, the end use should always be the primary consideration when choosing a two-cycle engine lubricant. NMMA TC-W3 lubricants are a major improvement over their predecessors, both in water-cooled and air-cooled applications. The new Global and JASCO system defines quality and the service application of air-cooled oils worldwide, and should be making an impact on the North American market shortly.
Although TC-W3® approved oils do meet some high temperature performance requirements, current ashless technology will not meet the performance requirements of Global "GD," "GC," or JASO "FC" for high temperature wear and scuffing protection. Nor are they required to be low smoke oils, which is part of the Global and JASO specification. A premium quality "GD" or "GC" air-cooled oil is specifically design for high temperature/output air-cooled applications and will outperform TC-W3® outboard oils in most high output air-cooled two stroke-cycle applications.
[ October 20, 2002, 09:13 PM: Message edited by: BOBISTHEOILGUY ]
Ted also on your redline comment. Almost all the top of the line two cycle racing oils out today have low ash additive packages. Ashless dispersents are useless above 300 degrees. A temp that the ring belt area on a high output two cycle reaches quit easily. I have used Redline oil in the past(about 10 gallons worth in various engines). A few thing i have noticed is that it does burn quit clean, It spooges quit bad in motorcycles that are not being run to the limit, it attracts water through plastic fuel cans(polyol ester problem), will tarnish carb jets, and will corrode cranks and other ferrous metal parts during storage.
BTW I am not Amsoil saleman or one for anyone else for that matter. I have never even used any amsoil products although Too slick did send me some info once.
Ben, which Red Line formula did you use?
I bought some Red Line All-Sport for my niece's Kitty-Cat snowmobile although she hasn't run it yet. Were you using Red Line's race formula (which is different)?
I would expect a race formula to be tailored to sustained high-RPM use and not designed for storage in bikes or gas cans (the moisture problems you cited).
--- Bror Jace
If you have the these "conclusions supported by the major two cycle additive companies," why not say who they are. quite frankly, this all seems more like marketing claims as well by this company. Where's those pics of your engine you have put so many hours on, please show us what they look like. I personally have seen many pistons from engines like the one I showed and for a 75:1 ratio, with all the hard hours it has on it, as this is a racing fool that runs this bike, fact is, he will start out backwards on the start line to give some of these guys a head start, so it has taken a big punishment, I find it not looking too bad for the variables involved. No question, It might have been better, but not all engines are alike as oils.
Please share with us the actual tech data sheet on this oil you use as well as some evidence of what you stated on your engine.
If this is true, why pull the motor apart? Seems like it didn't need anything.. Only reason why he pulled his apart was due to the broke powervalve, otherwise he'd still be running it.
I'm sorry, just too many people put claims up boasting about how theirs is bigger and better but can not show anything solid to support these claims, that's why I encourage people to post analysis,pics and anything else to help demostrate beyond any doubt short of company sales propaganda.
I rebilt the cr motor because I do it every year after the season is over. I everything was in spec , but cast pistons do have a service limit. The wiseco like the ones used in the gas gas you have photos of can go abit longure before cracking as they are forged. As Far as pics go. I tossed the piston when I replaced it, sorry about that. the oil I used was mobil mx2t. The specs are on there web site. Also keep in mind that the japanese oems reccomend a jaso fc low ash oil for there bikes and KTM recs a iso egd oil for theres. Boat (tcw3) oils just do not have the high temp additive packages needed to deal with high stress apps. Application wise boats are way differant than any other type of engine.
Bohb, I though I would add something. Phillips 66 has a excellant tcw3 oil called Injex. many people used it in snowmobiles and it worked grteat provided they didnt push the motors too hard and they didnt have exhaust valves. If the motor ran on injex had other of these two charachteristics it would cause heavy deposits in the ringland and powervalve area. To combat this problem Phillips came out with a iso egd oil called projex. Viola problem solved. Seadoo/skidoo recently changed there recs from using tcw3 spec fluids as have some of the other sled makers on egines with exhaust valves. Point of the hole thing is. tcw3 is a boating spec. It is easily passed by crap dino oil. Iso on the other hanbd is pretty stringent with no dino oils passing. All iso egd oils are dino PIB blends or are straight synthetics.
Ben,
I clearly talk to too many folks ....I don't remember you at all ...could be just old age
I'll have to check up on those 2 stroke specs a bit more ....
TooSlick
Bob, Quick question:
Was the ring free when you opened the engine or was it stuck in the groove?
I have seen so many 2-cycle's of all types with stuck rings. Piston ring deposits
are a major nemesis in my view.
I am currently running Schaeffer's TCW in my chainsaws and have seen improvements already.
Bob wrote: "It is not uncommon to see this with this oil. Many standard two strokes will create a hard carbon deposit mostly around the exhaust ports and"
Bob, With modern ISO EGD oils deposits like the photo shows are very rare. I have never had deposits of this sort when using low ash oils. You may say its not a problem, but it is. These types of deposits continue to build till the ring starts to loose mobility. When that point is reached massive blow by occurs which intern causes the ring to lose more mobility. Eventually the ring sticks and you have a scored cylinder. Aircooled motors like saws and trimmers are notorious for this. Thats why The oems of these engines reccomend low ash ISO EGD formulations.
Ted, You sent me some info about pc 5w40 about a year ago. Been useing it in my Cummins Dodge ever since with great results at a 10k drain interval. Better specs and analysis #'s than Delvac for $9 per gallon less money. Cant beat it IMO.
Ben,
I'll take whatever technical info you can send me on these ISO EGD, two stroke oils, in particular the BP "Indopol polybutenes" ...I'm still at the same address.
thanks!
Ted
Ted:
About the only Info I have on poly iso butene comes from BP's website.Most of the things i have learned on two cycle lubes have come from people I Have contact with in the industry.
I forgot to metnion the ISO spec is available somewhere online. Its a ***** to find though. Lubrizol use to have some good technical articles online, but I cant find them any more. Patent searches are also a good way to gain insite into formulations from specific MFG's.
