Super Tech lubes MSDS's
LA (Lower Alabama)
Attention WalMart shoppers (or is that just a KMart thing?) ... any of us that use Super Tech branded products and want to know a little bit more about (manufacturer, limited specs, etc.) them other than just pure speculation, here is the WalMart MSDS site:
http://msds.walmartstores.com/
I just put in "super tech," press enter and up they come.
Discovered it on an MSDS forum. Imagine that. How esoteric can this forum stuff get. In case anyone is interested, the URL for it is:
http://www.msdssearch.com/agnes/MSDS_Forum.htm
Huh. It won't let me read it.
Oh well.
Yeah, it's a pain in the rear. They are in .tif files. I had to save it to disk, then open it using the "Imaging for Windows Preview" program from Kodak.
I was unable to download this. File listed as corrupted QuikTime, this place is heavily fire walled. Could someone pull this up and post it directly here? Interesting to see that the dino. oil is listed as Warren. That much I could read. I had received a ST sheet directly from Pennzoil. Either they lost the contract or else Warren is doing the bottling. Also interesting to see that ST and Tech 2000 are listed together. Thought they were different products.
If someone can actually pull the data I'd appreciate it.
[ September 25, 2003, 04:53 PM: Message edited by: csandste ]
My Quick Time worked. The Super Tech Performance Engineered SAE motor oil, manufactured by Specialty oil Co., a division of Pennzoil-Quaker State.Shreveport, LA 71108 I think, not easy to read.
Walmart Super Tech 2000 5W30 is Warren Distrbuting, Council Bluff, IA 51501
I can't really read the rest very well
No problem for me. You have to download to your PC and open it. I use Download Accelerator and it does all the work.
TECH 2000 SUPER CONCENTRATED FUEL CLEANER
TECH 2000 SUPER CONCENTRATED FUEL INJECTOR CLEANER -- FIRST BRAND
SUPER TECH GAS LINE ANTI-FREEZE -- CRISTY
SUPER TECH BAR AND CHAIN OIL GRADE 30 -- SPECIALTY OIL
SUPER TECH SAE 15W40 UNIVERSAL MOTOR OIL -- SPECIALTY OIL
SUPER TECH OUTBOARD 2 CYCLE ENGINE OIL TC-W3 -- SPECIALTY OIL
SUPER TECH HEAVY DUTY TRACTOR HYDRAULIC TRANSMISSION OIL -- SPECI
SUPER TECH PERFORMANCE ENGINEERED HD SAE MOTOR OIL - ALL GRADES -
SUPER TECH MINERAL GEAR OIL SAE 90 -- SPECIALTY OIL
SUPER TECH SAE 80W-90 GEAR LUBRICANT -- SPECIALTY OIL
SUPER TECH SAE 30 UNIVERSAL MOTOR OIL -- SPECIALTY OIL
SUPER TECH R&O ANTI-WEAR OIL ALL GRADES -- SPECIALTY OIL
SUPER TECH PERFORMANCE ENGINEERED SYNTHETIC BLEND SAE 10W30 MOTOR
SUPER TECH TYPE F AUTOMATIC TRANSMISSION FLUID -- SPECIALTY OIL
SUPER TECH POWER STEERING FLUID -- SPECIALTY OIL
SUPER TECH SAE 85W-140 GEAR LUBRICANT -- SPECIALTY OIL
SUPER TECH UNIVERSAL 2-CYCLE ENGINE OIL -- SPECIALTY OIL
SUPER TECH PERFORMANCE ENGINEERED SAE MOTOR OIL - ALL GRADES -- S
SUPER TECH WHITE GREASE -- HYDROSOL INC.
SUPER TECH ENGINE DEGREASER -- HYDROSOL INC
SUPER TECH MULTI LUBE -- HYDROSOL INC
SUPER TECH CARB CLEANER -- HYDROSOL INC
SUPER TECH DEXRON III/MERCON AUTOMATIC TRANSMISSION FLUID
SUPER TECH RV WINTERIZER -- QUAKER STATE
SUPER TECH FULL SYNTHETIC SAE 10W30 -- SPECIALTY OIL (QUAKER STAT
SUPER TECH ANTIFREEZE -- PRESTONE
SUPER TECH UNIVERSAL PRECISE MIX 2-CYCLE ENGINE OIL -- SPECIALTY
SUPER GLUE GEL -- SUPER GLUE CORP(PACER TECHNOLOGY)
SUPER TECH SUPER CONCENTRATED FUEL INJECTOR CLEANER -- FIRST BRAN
SUPER TECH GAS TREATMENT -- FIRST BRANDS
SUPER TECH FUEL INJECTOR AND CARBURETOR CLEANER -- FIRST BRANDS
SUPER TECH & TECH 2000 WINTER FORMULA -25 WINDSHIELD WASHER FLUID
SUPER TECH & TECH 2000 WINDSHIELD WASH -30F -- SOUTH WIN LTD
SUPER TECH & TECH 2000 -20 WINDSHIELD WASHER FLUID -- SOUTHWIN LT
TECH 2000 & SUPER TECH SUMMER FORMULA WINDSHIELD WASHER FLUID --S
SUPER GLUE REMOVER -- PACER TECHNOLOGY
SUPER GLUE -- PACER TECHNOLOGY
SUPER TECH MULTI DUTY COMPLEX GREASE -- WARREN DISTRIBUTION
SUPER TECH MOLY LITHIUM GREASE -- WARREN DISTRIBUTION
SUPER TECH MULTI PURPOSE LITHIUM GREASE -- WARREN DISTRIBUTION
SUPER TECH R&O ANTI-WEAR HYDRAULIC OIL ISO 46 -- WARREN DISTRIBUT
SUPER TECH BAR AND CHAIN OIL SAE 30 -- WARREN DISTRIBUTION
SUPER TECH UNIVERSAL HYDRAULIC TRANSMISSION FLUID -- WARREN DISTR
SUPER TECH MINERAL GEAR OIL SAE 90 -- WARREN DISTRIBUTION
SUPER TECH SAE 15W40 -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 20W50 OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 5W30 MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 GENUINE 30W MOTOR OIL -- WARREN DISTRIBU
SUPER TECH AND TECH 2000 10W30 MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 30W MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 DEXRON III/MERCON AUTOMATIC TRANSMISSION
SUPER TECH AND TECH 2000 TYPE F AUTOMATIC TRANSMISSION FLUID -- W
SUPER TECH SAE 30 UNIVERSAL MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 GL-5 80W90 GEAR OIL -- WARREN DISTRIBUTI
SUPER TECH AND TECH 2000 GL-5 85W140 GEAR OIL -- WARREN DISTRIBUT
SUPER TECH 5W30 FULL SYNTHETIC OIL -- WARREN DISTRIBUTION
SUPER TECH FULL SYNTHETIC SAE 10W30 -- WARREN DISTRIBUTION
SUPER TECH SYNTHETIC BLEND SAE 5W30 MOTOR OIL -- WARREN DISTRIBUT
SUPER TECH SYNTHETIC BLEND SAE 10W30 MOTOR OIL -- WARREN DISTRIBU
SUPER GLUE PAPER GLUE -- PACER TECHNOLOGY
FIX ALL SUPER GLUE -- PACER TECHNOLOGY
SUPER GLUE FIX-ALL ADHESIVE -- PACER TECHNOLOGY
SUPER TECH ENGINE TREATMENT -- SPECIALTY OIL CO
SUPER TECH STARTING FLUID -- VALVOLINE
SUPER TECH MARINE HIGH VISCOSITY 80W90 LOWER UNIT GEAR LUBRICANT
SUPER TECH 50/50 ANTIFREEZE AND COOLANT -- OLD WORLD INDUSTRIES
SUPER TECH HIGH PERFORMANCE BRAKE FLUID DOT 3 -- SPECIALTY OIL
SUPER TECH MARINE GREASE -- WARREN DISTRIBUTION
SUPER TECH TILT AND TRIM FLUID -- WARREN DISTRIBUTION
SUPER TECH MULTI-VEHICLE AUTOMATIC TRANSMISSION FLUID -- WARREN D
SUPER TECH SYNTHETIC BLEND 10W40 MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH UNIVERSAL 2-CYCLE OIL -- WARREN DISTRIBUTION
SUPER TECH GAS TREATMENT -- PENNZOIL/QUAKER STATE
SUPER TECH CONCENTRATED FUEL INJECTOR CLEANER -- PENNZOIL/QUAKER
SUPER TECH FUEL INJECTOR AND CARB CLEANER -- PENNZOIL/QUAKER STAT
SUPER TECH PERFORMANCE ENGINEERED MOTOR OIL - ALL GRADES -- PENNZ
SUPER TECH RV AND MARINE ANTI-FREEZE -- FOX PACKAGING CO
24265 SEARCHED 77 SELECTED
[ September 25, 2003, 05:21 PM: Message edited by: Mike ]
I can get to the level where all the product is listed, just not to the second level that actually explains what's in there. Are these performance data or just safety sheets? Does Wally World have two different lines of dino oils, Warren AND Specialty?
When I screwed around with trying to load into QuickTime it actually bombed my entire system and I'm running Windows 2000, not 98 or Melenium or one of those unstable OS's.
They are the Material Safety Data Sheets. The ones from Specialty Oil contain some useful information, i.e. base oil CAS #'s, chemical compositions (within ranges) and physical characteristics (viscosities at 40C and 100C and flash points). The ones from Warren Dist. fairly well contain only flash points.
[ September 25, 2003, 05:54 PM: Message edited by: doyall ]
Try right click and do a "save target as" then open them from your desktop, on my system they open in my photo program. They don't tell you much about the synthetics.
[ September 25, 2003, 05:58 PM: Message edited by: Bob Woods ]
Got it. To me it looks like Warren Performance has replaced Specialty as the supplier of Wal-Mart oils. The 15w40 product on the shelves (Specialty/QS) is SJ meaning it's old stock that hasn't been updated. Most of the new stuff is Warren. Warren has product sheets on their site.
