have a chevy impala for a rental, 2006 I believe. It has less than 3k miles on it. I'm in West Palm FL.
question- the dash driver's info display has a compass but it needs to be calibrated. It says press button to start calibration, then tells you to drive in circles. So we drove in circles in a parking lot, first around an island so it was a mini oval, then we did a tight circle. Maybe the tires need to be squeeling when you do this? We spent 3-4 minutes, did circles in both directions, and it never said done. anybody know what gives?
other thing is there's a wild resonant percusion when you open either one of the back windows by themself and are doing 40+ mph. The wind goes thump thump thump inside the car, like if you had a 1000 watt subwoofer at max volume just thumping air. It hurts your eardrums. Anybody experience this? Maybe it's just unique to this car, hopefully for GM's sake. If you open the front windows an inch or open the other rear window it doesn't happen, only when one rear window is all the way down.
