Originally Posted By: hybridcars.com
German automotive supplier Bosch says it’s the first and only supplier to offer water injection to reduce vehicle fuel consumption and carbon emissions.
Bosch’s new WaterBoost system is geared to drivers accelerating quickly or driving on highways, where the additional injected water reduces fuel consumption up to 13 percent. The higher compression ratio in the engine also leads to a carbon reduction of up to four percent in WLTC (Worldwide harmonized Light vehicles Test Procedures), Bosch said in a press release.
Midsize cars will see the best WaterBoost fuel economy performance, with the system ideal for three- and four-cylinder downsized engines typical in new car models, the company said. The new water injection system can also make cars more powerful, especially by providing more kick to turbocharged engines, according to Bosch.
Quote:
The BMW M4 GTS, a high-performance luxury coupe capable of hitting 493 horsepower, is the first production vehicle to use a water injection system. Bosch said it’s supplying water injection parts for the car. That offers the turbocharged six-cylinder engine improved performance and consumption even at full load.
Bosch WaterBoost uses a port injection system that only requires a small amount of water to be kept onboard. It uses a separate water tank filled with distilled water that will need to be refilled about every 3,000 kilometers (1,864 miles).
With 99 cents a gallon at Walmart, cost of refill distilled water every 1500 miles is nothing.
http://www.hybridcars.com/bosch-water-in...rbon-emissions/
