If can inspect, would be fine. Cuts on the adbv and nearly closed louvers inside the center tube are the usual issues. I would have used them except for those defects on mine. They don't have a tearing problem, it appears to be the same media as used On Mercedes OE called fleece filters, which is Mercedes recommendation for extended oil drain filters.
