My Galaxy S3 has developed the dreaded GPS problems and the solution most people recommend is to remove the backplate, clean the contacts that connect the backplate to the motherboard with rubbing alcohol, add a conductive grease to the contacts, then reinstall the plate and tighten the screws.
Is there a readily available over the counter product I could use for this application? Something that helps electrical conductivity?
Thanks!
Thanks!
