Wow lots of responses...
Originally Posted By: UncleDave
There is no naturally aspirated half ton v8 truck that pulls in the heat and altitude like an ecoboost. Full stop.
Except a diesel I assume. :^) It just that it does seem to cost as much as a diesel though, but still (afaik) can't match the BSFC of a diesel under heavy load, even if it may be better than other gas engines under load. It just seems real expensive for what it is - looking at crate motor prices which I assume represent what they actually cost it was thousands more than I was expecting.
I wont disagree turbos are best for altitude whether on gas or diesel engines. Nor am I claiming the Ecoboost doesn't sound like a great quality of tow with a wide flat torque curve starting low and strong. It just doesn't seem all that 'Eco'.
Originally Posted By: Gillsy
I hope this helps although it may not directly address your concern. I drive a 2016 F150 Supercab w 2.7 Eco.
I'll agree those are good figures for a pickup, but they seem like what all the newest pickups are getting?
Originally Posted By: volk06
First off ford does not use cylinder deactivation on the V8 unless that recently changed. Also, the MPG are not near the same. Are you sure you're comparing all Ford engines? Also why does everyone assume these engines are overworked? They build these bottom ends pretty solid.
It's not the bottom end i'm concerned about, it's the rate of wear under real world "start, drive to work, stop and let cool half the day, start, drive back home, let cool overnight" conditions, instead of the 200,000 nonstop duty test that Ford did in their promo videos. Not that i'm ridiculing those videos, that's still impressive, but i'd assume the Chevy (and Dodge) would do the same with a normal v8 too when even the old Chevy LT engines would go half a million in taxi service. I'm wondering whether the Ecoboost will go half a million in real world but we won't know for awhile yet. All I know is that so far nobody has ever made a turbo gas engine last super-long (or as long as the nonturbo version) so i'm a little skeptical.
For MPG
https://www.fueleconomy.gov/feg/byclass/Standard_Pickup_Trucks_2WD2016.shtml
Chevy 5.3L V8 with it's cyl deactivation lists as 16 city/23 highway with 6 speed automatic
Ford 3.5L V6 Ecoboost lists as 17city/24 highway BUT thats with the new aluminum bodies too
If we roll back to 2014 when the Ecoboost first came out before the aluminum body
Ford 3.5L V6 Ecoboost lists as 16 city/22 highway with the 6 speed automatic
So isn't it the aluminum body responsible for +1/+2 mpg more than the Ecoboost? The ford is a 365hp engine the GM 5.3 V8 a 355hp engine, they seem pretty closely matched.
Please don't get me wrong, i'm not saying it's a [censored] engine. It just seems like throwing alot of money and technology at a problem which i'd then expect should be beating everyone leaving them in distant second place but seems not much better (2014 pickup mpg figure vs chevy v8) when I assumed the whole purpose of a downsized engine was a downsized fuel bill with the same performance. I was hoping it was more than just high altitude tow performance mostly.
That being said i'm still looking forward to what they'll do with their 2nd generation Ecoboosts i'd read about in some tech documents which might be closer to the stated goal of better BSFC under all load conditions.
