So i'm looking at newer truck specs, and i'm comparing two engines... one conventional v8, and this new fangled ford ecoboost. And let me be honest - I just don't get it. The v8 (with the 4cyl multi displacement whatever mode) shows better MPG on the highway, the power of both engines is about the same, when I hear of people towing with the Ecoboost heavy figures they report the single digit tow figures i'd expect elsewhere, and then I look at crate motor prices and the Ecoboost is priced as expensive as a diesel into the five figures.
This isn't meant to be a Ford bashing thread but what am I not getting?? :-/
I read some article on what it's MEANT to do, I just don't know if it's doing it. I saw technical papers talking about how engines show the best Brake Specific Fuel Consumption under higher loads and lower rpm's, and in theory the Ecoboost is trying to widen this "higher efficiency island" over a much much wider range of rpm and loads using the turbo, somehow. It just seems that it's not actually doing it very well in the real world while costing more than the v8's its claiming to replace with worse mileage. I'd also be concerned about lifespan of a small displacement overworked engine - and yes I know about Ford's "nonstop 200,000 miles driving/ heavy construction work/ etc" promo puff pieces except that starting and stopping the engine on endless short trips is going to be harder on it than nonstop driving anyway.
