Originally Posted By: dlayman
Getting them clean isn't generally the problem. Keeping them that way can be. Many techniques will work to clean them with a little work. But if you don't seal them properly they'll be yellow again in a few months. Hopefully the Collinite works. When you use an abrasive on them, whatever original sealant was still on them is now gone and needs to be replaced ASAP. Even when well sealed you likely will be repeating the job at some point. Frankly, I don't know why this needs to even be a problem. Surely the lenses can be formulated with a material that isn't going to yellow and fog with age, and it can probably be done quite cheaply, many inexpensive UV inhibitors are available. In some ways I think the old sealed beam glass headlights were superior.
A local detail shop charges 25 per light to clean and seal them with lifetime warranty if / when they cloud again, which if you keep the car long enough they probably will.
Yes, seems to come back quicker. I clear-coat them. Helps for a few more years.
