- Joined
- Jul 2, 2007
- Messages
- 5,294
Braces. I'm 53, and I've probably needed them since age 15 but large blue collar family and tight budget meant a no go, and into adult hood I never worried much about it just kept up good oral hygiene and keep 'em as white as possible. Over the counter white strips don't work well due to a couple displaced teeth so I use custom molded upper/lower trays and the paste. Anyhow, all I really need is upper right incisor (adjacent to upper right canine) moved forward from behind and into place, and lower right canine moved backward and into place. Crowding. Did a consult a while back and the Orthodontist formulated a treatment plan that would span about 18 months to two years that will straighten everything up but wow-- a lot of stuff needs to be done: extra space grinded-in (little emory wheel thing or something) in between a bunch of teeth to make room instead of pulling any teeth, and then they need to put some kind of hard blue substance onto topside of rear molars to open up the bite or occlusion while the treatment plan is going on. The hard blue stuff stays there the entire 18-24 mo time period of treatment with braces. And rubber bands to help "procline" or something the front teeth.
The out-of-pocket after insurance is attractive: $1800. And effective January 1st my employer is gutting employee health insurance benefits including dental and devolving it down the minimum required by the federal affordable care act, while keeping employee premiums the same. (Thank you, oh affordable care act).
So I need to decide once and for all if I want to go through this with a set of rail road tracks, asphalt (the blue stuff), and serpentine belts (rubber bands) installed in my face for about two years, because the Price Is Right for only four more months.
Mainly hoping to hear from anyone who's undergone orthodontics as an adult.
