Triple_Se7en
$50 Site Donor 2024
Ever since I loaded the most recent Windows 10 Anniversary Update, the blank white box used to type text commands for System Configuration results does not save what I type. A most recent command-example is the commonly used MSCONFIG.
BTW..... I have Classic Shell Start Menu 4.3 installed. I access ''RUN'' thru it.
Thanks in advance for any help in this matter.
