Here is an excerpt from my explorer's owners manual. Can't say its bad advise, but it doesn't go into much detail either! FWIW, I will likely be using up my Meguiars leather cleaner and leather condition bottles before looking for the next best thing.
Originally Posted By: Ford
Vehicle Care 351
2014 Explorer (exp)
Owners Guide gf, 3rd Printing, September 2013
USA (fus)
CLEANING LEATHER SEATS (IF EQUIPPED)
• Remove dust and loose dirt with a vacuum cleaner.
• Clean spills and stains as quickly as possible.
• For routine cleaning, wipe the surface with a soft, damp cloth.
For more thorough cleaning, wipe the surface with a mild soap and
water solution. Dry the area with a soft cloth.
• If the leather cannot be completely cleaned using a mild soap and
water solution, the leather may be cleaned using a commercially
available leather cleaning product designed for automotive interiors.
• To check for compatibility, first test any cleaner or stain remover on
an inconspicuous part of the leather.
• Do not use household cleaning products, alcohol solutions,
oil/petroleum-based leather conditioners, or solvents or cleaners
intended specifically for rubber, vinyl and plastics. These products
may cause premature wearing or damage to the leather.
Vehicle Care 351
2014 Explorer (exp)
USA (fus)
