It's getting to the time of year when the sun will set late but the grass is still growing. I had to finish up mowing a few times last year with the yard almost totally dark at 7:45 PM or so. The stock headlights on my Deere D105 stink. They're enough to get across the yard, not to cut effectively.
I'm thinking of adding two small 18 watt LED lights that would draw 3 amps in total when lit. According to the manual, the charging system has a capacity of 9 amps. The OEM 1156 bulbs are supposed to draw 2 amps each. I'd wire it so the LED lights would be the only light source. Seems like it would work fine to me.
Anybody else venture down this path?
