Originally Posted By: rwood
I have a press in wheel stud that was spun . Searched , no luck. It has on the head an H , underneath that the numbers stamped 5419 FCA.I would like to know who manufactures this stud. The under head length is 2.2.35 approx, overall length is 2.65. The thread length is 1.50 with the nurl , as far as I can makeout is .550 . Any help would be great.
Are interested in who manufactured the stud so you can get reimbursed for the work involved in fixing this? If so, I think you are barking up a dead tree. FCA is Fiat Chrysler Automobiles, so they would be the ones who would know - and they would be the ones to handle the warranty - if applicable. It is very likely not, as these types of parts are only sort of covered by the original vehicle warranty.
But if you are interested in replacing the stud, any parts store will have replacement studs (although not every store has every replacement part in stock, but they can be ordered.)
But was the problem the part that the stud presses into? In that case, you don't need to know who made the stud. You need to get a replacement for that part - and again, FCA would handle the warranty - if applicable.
