Originally Posted By: artbuc
Originally Posted By: TiredTrucker
Depends on what one is using them in. They are great in applications like semi trucks, ag equipment, etc. And I have found them great for my personal stuff also. Makes changing oil a much cleaner proposition. Especially on stuff like my pickup, where the drain plug is on the side of the pan and when only using a drain plug, the oil shoots out and sometimes the drain pan is not quite perfect to catch the stream when it starts. With a Fumoto and a plastic elbow placed on the nipple, I get a nice downward drain. And try changing 10 gallons of oil out of semi truck, in your drive, doing the plug method. No, I will take a Fumoto. Only those that have very limited experience cannot understand why anyone would use them.
Guess you're right. I have been changing oil for only 51 years on only 18-20 various passenger vehicles.
Me too! First drain I did was around 1965 myself. But one thing I learned over the years in many of my endeavors, is to work smarter, not harder. And several profs in college beat it into me that if there is an easier way to do something, that is the way it should be done. That bit of advice has proven well over the years.
