Originally Posted By: meborder
100% spot on, Ducked
Thanks.
It is just my interpretation of my (and now the OP's) symptoms, though. I can't prove it, and can't think offhand how you could.
Just to clarify for the OP, although I think wet fluid is probably the cause of your problem, its quite likely that there's some brake binding which is causing it to boil, (though it could also have been driver action.)
IF you can safely test drive with the wet fluid, it might be worth looking for this first, since it'd save on a double-flush. I'd think an IR thermometer might be useful for this, though I didn't use one.
If not, a double-flush might be of some benefit anyway. I've done 4 or 5 flushes in the past year or so due to piecemeal fixes, which is too many. No big deal, since the car isn't ABS so its not tricky to flush or refill, but it would have been more efficient to do all four corners at once, if I'd had time.
NOTE that, if a binding caliper is anything like as sludgy as mine was (and after 18 years it might be), flushing wont clear it and it'll have to be stripped (which is what I did) or replaced (which is what I dd with the wheel cylinder).
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4072698/2
NOTE also, that, if you flush the system using pedal pushing, you should be very careful not to exceed the normal range of pedal movement, which is likely to damage seals in a corroded system. I now prefer to (a) gravity flush or (b) use a syringe. I've back-flushed with the syringe using fairly high pressure without any adverse consequences, but have been told that this can cause master cylinder failure, I think by everting seals.
Some related online discussions
http://www.forumosa.com/taiwan/viewtopic.php?f=75&t=149612&hilit=hydraulic+wise#p1692651
This is the (defunct but still, for now, archived) Forumosa site. Quite a lot of misinformation, but there is detailed a mechanical handbrake fault on the Mazda 3 that could credibly lead to these symptoms. I dunno if this could also apply to an old Civic but I'd have thought its unlikely.
http://www.honestjohn.co.uk/forum/post/index.htm?t=109769
This is the UK-based Honest John site. I don't post on there very often because the pundits tend to be pompous and patronising and I get into fights that are a waste of time. Not too bad this time.
"Bolt" (who appears to be a pro mechanic) gets a bit snippy with the suggestion that brake fluid can boil. I'm sure this is an honest opinion, but someone once said (I think in the context of nuclear experts) that it was quite difficult to get someone to see the obvious if their salary depended on them not seeing it.
