Our brakes were making a grinding sound and felt "gritty" in the pedal.
Turns out that the front passenger side lower pin had "seized" and was rusty and rough causing the pad to wear unevenly. I'm going to replace the pads and hardware along with the pins. I've only ever done pads, hardware, rotors...
...so are Carlson slide pins a good aftermarket option? Or should I run to the dealer?
And what's everybody's favorite brake lube and why? JUST KIDDING! Not gonna open that can of worms
