Or Rounding Off the Usual Suspects
Here's a trick that I probably can't try here but might be possible elsewhere.
Back in The Yook I had an old, traditional heavy soldering bit that I always thought would be useful for "surgically" applying heat to the usual suspects, the usual suspects here being the stuck-fast-nasty-little-cross-head-screws that Japanese motorcycles are infested with.
But I didn't have a Japanese motorcycle then, so I never tried it.
This kind of thing.
http://josephjenkins.com/store/images/C/Johnson_hand_copper_cat.jpg
Unlikely I'll find one here, but if anyone tries it, I'd be interested to know how it works out.
The suspects in the current case are a couple of stuck-fast-nasty-little-cross-head-screws holding the master-cylinder reservoir cover on a Yamaha RZR.
These little F****ers
IF I get them out I'll put polythene or PTFE round the replacements which will hopefully stop them doing it again, but getting them out is the trick.
I have a couple of hit-it-with-a-hammer impact drivers, one of which has sometimes worked in the past, but It was the work of a moment this time to chew up these screws with it.
Perhaps my technique isn't correct. I've only used it with a club hammer, so possibly a dead blow hammer (which are available locally) would work better .
Although impact drivers are readily available here, a decent range of cross-head bits for them isn't. They come with maybe two in the box, and I've been able to buy a few loose, but no set.
(I do have a pretty comprehensive set of splined bits, which is no use to me since the car I got it for is gone.)
Ill-fitting bits are therefore a hazard, but I "auditioned" all my bits before hitting anything this time, and the one picked for the role seemed to fit pretty well.
I wonder if an electric impact wrench gizmo like this would be better?
http://goods.ruten.com.tw/item/show?21305080186330
http://goods.ruten.com.tw/item/show?21404016453583
Probably too late for these little FASTNers, though, so it looks like drilling and screw extractors, though I don't recall any successes with anything that small.
Best case, I see me in the near future attempting to explain that I want reversed drill bits to a Taiwanese tool store owners daughter.
I'm screwed.
This kind of thing.
I'm screwed.
