I have the rear bumper off my truck right now to touch up some scratches and light rust in the rear lower fender/rocker behind the bumper. Inspection shows the rear of the bumper is in really good shape, possibly related to yearly fluid film application (over top of an initial Amsoil HDMP application). A good washing with simple green did not remove all of the black coating, though I'm not sure what that is. There is a bit of light surface rust on some parts, and one of two spots are getting a bit heavier.
I'm torn between brushing on fresh fluid film and bolting it up- very easy to replace if the need ever arises and the one side is already slightly bent... On the other hand I could grab the drill and wire wheel and go to town; this would be followed by Rustoleum Rust reforming primer.
Opinions?
Opinions?
