Originally Posted By: i_hate_autofraud
You can wait and use the GM interval. Check your oil monthly and you'll see the oil use if any and how the oil darkens with use. That way you'll be confortable.
If you see any water/condensate in the oil, I'd be surprised, late model engines run cleaner then ever.
Q > is the oil filter a spin-on or a cartridge?
I put a pair of FilterMags on all spin-on oil filter applications, I can go 8,000 miles before the oil even darkens, UOA show 60% wear metals then before!
The filter is indeed a spin-on. And, I do happen to have a pair of FilterMags on the filter, and a Motion Pro magnetized washer around the center of the oil filter, and a Gold Plug magnetic drain plug. Overkill, I know, but it's the BITOG way.
