Originally Posted By: OldEuroCarLover
Originally Posted By: Ohle_Manezzini
I liked more the Subaru version. I felt that it Kept the foam longer on the wetted parts.
Originally Posted By: Vincsant
I have used Delco X66 since the early 1980's there is nothing better to clean the combustion chamber. I remember about 25 years ago I ran it through a 6 cyclinder engine that had bad cam lobs on one cylinder, that cylinder essentially wasn't working. After pulling the head 5 out of 6 pistons, valves, and head only had a dusting of carbon. The bad cylinder had a thick crustation of carbon, oil ash etc. By the way, the P in your X66P indicates a pint container.
I think the P is meant to mean "pour." There's an X66A, which is an aerosol. A lot of people think the X66A and the Subaru aerosol are the same product.
BMW makes a fuel injector/combustion chamber/valve cleaner that's identical to the X66P. Same bottle, same color fluid. Different label.
Yes, you're right. I was talking about the aerosol versions of both. Liked the subie more.
