Decided to do my own oil changes in my new to me Chevy Express 3500 Van. I got a little over whelmed last time I started doing research into what oil to use in my Motocross bike so I was dreading this (I may be reopening that research as well). Hopefully someone can help make this task much easier, or at the very least give me a solid starting point to get me through until I can do further research. So here it goes.
1. Vehicle is a Chevy Express 3500 with the 6.0L.
2. Owners manual calls for 5w-30 with GM Standard GM6094M and API certification. It does not give a change interval instead the engine computer has some algorithm it uses to determine when it needs to be changed. (Side note: Does anyone know if that is trustworthy?)
3. I live in Michigan but will be traveling to Florida with the van in the winter.
4. I drive pretty easy when I drive this van. I try to get as good as gas mileage as possible when driving it. Normally set cruise at 68.
5. This van will only be used on weekends for longer hauls. It's used to transport my motocross bike to and from tracks. Most are an hour drive or more. And mostly highway.
6. Van has no problems. Compression check was good. lowest cylinder read 160psi and the factory manual calls for a minimum of 100psi. The spread between cylinders was less then 30% per the manual. It does have 166,000 miles on it so I'm not sure if high mileage oil is a worthy investment or a marketing ploy.
I could put this in another sub forum but any quick advice on an oil filter. Read some brief things in that forum waiting for my approval and it seemed some people were really against the louvers and other filters had very small amounts of filtration media when cut open. Any quick advice would be greatly appreciated. Otherwise Ill search that forum more now that I have that function.
I understand there is not one superior best oil in all situations. But I hope to at least get some advice on decent oils and filters and avoid the possibility of using junk in my engine.
Thanks for any help,
Matt
Matt
