I took a trial run at some of the buff and polish work that I'm going to have to eventually do on my daily driver Focus today. I knew the headlights needed work. Here I did the passenger's side and left the driver's side for comparison:
I also buffed, polished and waxed only the fender so far, you can't really tell any difference but I think at night under lights in the parking lot at work I'll be able to see that the swirl marks are gone:
This car is nearly as bad as a white car. I took it to the car wash the other day and I can't believe all the 'black stuff' that came out from under the door trim at the top of the door below the window. I need to hand-wash it good and get into the door jambs and around the trunk area, etc.
