How can a shop make decent money charging only $100 to drop the gas tank and replace the pump? That era of truck , I think, needs the fuel pump pigtail replaced also at the time of pump replacement.
It certainly helps that you are not in the rust belt. Still, a hundred dollars?
What make of fuel pump was installed?
