Originally Posted By: DrRoughneck
Originally Posted By: Cujet
Often carbon deposits are self limiting and not detrimental to performance or longevity. It's rare that an engine will build up carbon to thicker and thicker levels until mechanical interference results.
In addition, carbon has a small insulation effect. This tends to slow heat transfer, a good thing indeed.
Carbon depostis can "glow" causing pre-ignition, leading to pinging.
They can, especially in highly loaded engines. The reality though, is that "glowing carbon" is not a common problem. As the stuff that is thick enough to glow tends to burn off rather rapidly.
