Last winter, I bought a 1996 Ford F150 with a 302 engine. The previous owner had neglected the coolant, it was rusty and the heater core was clogged. I immediately did a flush and fill and back flushed the heater core. That got me some heat last winter and bought me some time.
Last month, I installed the Prestone back flush tee and Prestone flush. After repeated flushing, I ran distilled water through the engine a couple of times and felt as if I had done a good job. Refilled with Zerex G-05 (50/50). I used the Zerex concentrate and distilled water for the fill.
About two weeks ago, I noticed the coolant still had what appeared to be very fine rust particles. So, today (8/22/2016) I installed a "Dorman HELP! 55242 Fuel Line Filter" in a coolant bypass line. The truck has 128900 miles on it today. After idling until the thermostat opened, I noticed the filter turning dark. I will post back the results of running this filter in the coming months. I don't drive this truck much, so reports will be sporadic.
Dorman 55242 on Amazon
