It has been over ten year since we last purchased a new vehicle. For decades there was always a recommendation to change oil the first time anywhere from a few hundred miles in up to 1,000 miles depending on the manufacturer.
Now it seems that most companies say to just leave the factory oil in until the first normal interval. I've even seen comments suggesting that the factory fill and/or factory assembly lubes have some beneficial additives for initial break in that refill oils do not.
So I'm conflicted. For long term durability, is it best to leave the factory fill in until the maintenance minder says to change it, or should I do something at around 500 to 1000 miles? The trivial cost of doing my own oil change isn't a concern.
What will best help for long term durability?
