I'm getting rid of the one I have now--it is too floppy and the fluid runs out too much when I try to pour it into the jug. So hard plastic is one requirement.
Are there any drain pans that you would recommend--or recommend that I stay away from? I'll be using this for draining oil and coolant, although my next coolant drain is 3 years away.
I'd like to stay under 20 bucks if in any way possible.
