I wanted to see what the great BITOG minds think about this. I’m not sure I know what to make of this.
I picked up 5 M1 filters at Advance using my various speedperks coupons that were going to expire. Came out to a great deal for these. I always looked at these as a high quality filter until I started running them. The filter is a M-102 for a V6 Camry.
I used the first filter in June and the second in July. I did not see the problem so much with the first filter but the second filter definitely had an issue. The oil light was staying on longer than normal at each start up. I hadn’t seen it like this since my Pure One ADV blowout a few years ago. I was immediately thinking the same issue occurred with the M1. I piled 5,000 miles on the car in about 3 weeks so I decided to see if there was a filter issue.
Prior to dumping the oil, I checked the 3 remaining M1 filters. Blowing through the center hole I immediately realized there was an issue. The air was easily flowing out between the base plate and can. All 3 filters were like this. No way was I going to use them. Headed over to WM to pick up another filter. While in the store, I checked all the Fram brands and was not able to blow through any of them, the result I would expect. Ended up grabbing a TG3614 filter.
A half hour after returning from WM I pulled the filter and it was empty, no mess at all during removal. Every other filter I have removed other than the P1 resulted in the filter emptying upon removal. I cleaned the filter base plate up and was able to blow through this one too. For those unfamiliar with the Toyota 1MZ-FE, the filter mounts at an angle where the filter is about 45 degrees upside-down.
Question - Is this normal for M1? How can this be with every filter I have? Manufacturing defect? I plan to contact Mobil regarding this issue. After looking at them I can see a gap where it looks like it should be a solid connection.
If it means anything, the codes on the filters I have left are:
051815AF 10:56
020816AF 17:53
030516AF 05:08
All made in the USA. I’m guessing these are the manufacturing dates. If so, it leads me to believe this is a design flaw since the dates are varied. How can they design a filter that empties when mounted inverted?
TIA. Looking forward to the feedback.
051815AF 10:56
020816AF 17:53
030516AF 05:08
