Great site here, have been reading and learning for a while. First post, tried searches sorry if this is all redundant, if I missed an obvious thread/post please help with a link.
2016 Nissan Frontier Pro-4X 4.0 V6, 6spd 4x4 with rear locker.
I am a firm believer in early fluid changes to flush out initial wear and would like to change the fluids in the front and rear diffs, the transmission and t-case.
Nissan OM recommends the following:
Front diff- Genuine Nissan Differential Oil Hypoid Super GL-5 80w-90 or equivalent conventional (non synthetic)
Transmission- Genuine Nissan Manual Transmission Fluid (MTF) HQ Multi 75w-85 or equivalent. If NISSAN MTF if not available API GL-4 75-85 may be used as a temporary replacement however use genuine NISSAN MTF as soon as it is available.
Tcase- Genuine NISSAN Matic D ATF. Using Fluid other than NISSAN Matic D will cause deterioration in driveability and transfer durability and may damage the transfer, which is not covered under NISSAN Warranty.
Rear diff- Genuine NISAN differential oil synthetic 75w-140 or API GL-5 synthetic gear oil.
I have no objection to using the factory fluids and most likely will, but what are they? I've read here and on the Frontier forum that Nissan's ATF is essentially Dexron-III. Is it really the same, what's different, would a Dexron-VI or other be better than Nissan's ATF in the tcase?
Same for the transmission- what is Nissan's MTF that is different/better than another 75w-85? I understand not using a GL-5 for the syncros but would something else be better?
They don't seem so picky re the diffs. Any reason not to run a synthetic in the front? If sticking with conventional in the front and synthetic in the rear which brands to use?
Thanks, Matt.
Thanks, Matt.
