FWD with V6. Was driving down the road today about 55-60 miles per hour and all of a sudden the vehicle went to idle and you could give it gas but no RMP's at all. In the dash where fuel gauge is the orange square lit up flashing with a wrench in it. I put it into N and coasted to nearest driveway. Then I put it in park. The car was still idling and the ac was on but I tried to give it gas again and it got real rough and almost died so I turned it off for about 10 seconds. I started it back up and has been fine since went about another 20 miles no problems or lights on. Any idea what could have called this? In the book it says the orange light with a wrench means: Illuminates when power train or an AWD fault has been detected. (The vehicle is not AWD by the way) Contact your authorized dealer as soon as possible it says.
My niece has the 2012 Ford Fusion car and she said hers done same thing not long after she got it. It was still under warranty so she took it in and it was the throttle body. Was a $400-$500 fix. Should I just drive it if no lights or warnings are on or call dealer Monday morning? The edge currently has 79,000 miles on it.
