Last weekend and into the beginning of the week, I performed 4 drain and fills with distilled water on the cooling system of the Jeep. The system holds 15 quarts and 8 quarts drain out when the lower radiator hose is pulled. (I skipped the petcok)
I refilled the heater core, radiator and expansion tank with 8 quarts of straight G-05. (8 quarts of straight coolant with a 15 quart capacity.) The expansion tank was nearly filled to the top, but as the system burped itself over the first drive and having the heater on, it went down to a normal level. Then, once again having the heater on full blast and driving (heating/ cooling) over the next couple days, it fell halfway between hot and cold marks once hot and just below the cold mark when the engine is cold.
My question is, when the system is hot and the radiator cap allows coolant to travel to the expansion tank, what sort of mixing happens? Would the coolant in the tank be mixed just as much as what's in the rest of the cooling system by now? I'd like to top off the expansion tank with 50/50 to the correct level, but if it isn't thoroughly mixed just yet, I would like to hold off and not dilute the straight coolant since I would like it to be mixed with the whole system.
