I've installed many manually transmissions. this is my first auto. I'm having some difficulty in getting the torque converter studs to align with the flex plate while also aligning dowel pins.
any tips other than the obvious "keep wrestling with it?"
I did make one mistake - I forgot to mark the proper flex plate holes before installing. (this is a "universal" zero balance flex plate, since we internally balanced the engine; and there are alot of "extra" holes in it. )
351W
351W
