Originally Posted By: 4evrnyt
After reading the Oil 101 article I came away wondering; if synthetic oil doesn't change grade over time why would anyone need to use higher then 30 grade. If most engines require 10cs at operating temp and that can be achieved with 30 grade oil what benefit is there to running a higher grade synthetic oil then 30 grade?
I've repeatedly asked the author of 101 where he gets the understanding that engines are designed for 10Cst KV100, and hear chirping crickets every time, then some time later he'll point newbies back at it.
Manufacturers don't spec a KV100 directly, but they DO spec it indirectly by speccing different grades, the latter number of which has a range of KV100s.
More recently, focus has been on the viscosity characteristic that actually DOES most of the protection, and that's the HTHS...again, misconstrued in 101 by interchanging Cp and Cst.
Lots of manufacturers have set minimums on HTHS, and seeing as you have specifically mentioned "30s", a straigh mineral SAE30 dino will have an HTHS in the range of 3.5, and the multigrade synthetics can go from 2.9 (ILSAC economy grades) to 3.6+ (ACEA A3/B4, C3 type oils).
