I own a 2012 Acura which came with a factory TPMS which seems to work great, even I have rotated the tires. The car was off the road for three months due to the Takata air bag recall, and when I started it up again, two of the tires were low. My local Acura dealer diagnosed one of the tires as having a bad washer on the TPMS and replaced it under warranty, although they said nothing about the other tire which was low, and simply filled it up with air. That tire has an extremely slow leak, so slow it has been hard to detect. I finally realized that it is leaking, maybe a pound a week, but thinking that if has a slow leak now, it could develop into a fast leak at some point. I have a job that requires me to get to work on time, so I dropped it off at a tire store, one which seems to know what it is doing. They confirmed that the leak was coming from the TPMS, but did something weird--they removed the TPMS, which on this car seems to be all part of the stem, and replaced it with a conventional stem. They told me to go to a dealer, which I would have done in the first place had I known that a modern tire store was incapable of replacing a TPMS sensor, or better still, just replacing the washer, which is probably all this one needs. Now I have to go to my dealer. so here are my questions:
Will they charge me for programming the system, when rotating the tires did not require reprogramming?
Should I buy a new TPMS stem, or ask them to try just replacing the washer first?
How long do these sensors last? Does it make sense to have one new one and three old ones on the car?
Does the tire need to be rebalanced after the sensor has been worked on, whether replaced or just had a washer replaced?
Could I have avoided all this misery just by taking a 10 mm wrench and torquing the little nut on the valve stem tighter?
