Originally Posted By: Wolf359
They're standard in certain cars like Mercedes. There's plenty of stories of them lasting 8-12 years. Still it depends on temperature, the colder the climate, the longer they last just like any other battery.
That would mean they became standard in 2004 to 2008. In my limited observation, I haven't seen that.
Regular batteries in Mercedes have been reported to last 8-12 years as well. These are made in Germany batteries.
The AGM I have self limits charging voltage.
An upside of AGM is it accepts charging more readily and it resists a greater depth of discharge. Regular batteries need hours on absorption charging to fully top up.
So if your driving pattern is shorter trips and liberal usage of accessories, then AGM may be for you.
But heat is the main killer of batteries so if you're doing longer trips and the battery is subject to heat, then there's probably no advantage. AGM won't last longer but it'll cost you more.
