Wow, I think this soak did some good. I know it is too early to claim victory, but I have put 378 more miles on the car since the oil Change and the level is still above the hashmark area.
Here is what I did.
Added 2 ounces of Chemtool to each piston. Let soak for a few hours. I refrained from bumping the motor since Chemtool would remove any oil film
I then sprayed a liberal amount of PB-Blaster to each piston top and let it sit a long time before spinning the motor.
After a few hours I put a couple ounces of Rislone Engine Treatment Concentrate in each cylinder. Every so often for the next couple days I would bump the engine for a couple seconds.
I used newspaper folded up to soak any pools of fluid remaining.
