Originally Posted By: CapriRacer
Just so everyone understands:
The issue with the dots being aligned with the valve stem is NOT about balance. It is about uniformity (Think "roundness" and you will be close.) The idea is to make the assembly as round as possible and NOT to reduce the amount of balance weights needed.
In some cases it is about balance.
Check out the link I posted above. Sumitomo says they have two marks on their tires, which includes a yellow mark for balancing purposes. They also include a red mark that is for the runout purposes you describe.
Quote:
The Balance Marks will be indicated as follows:
Yellow - Within 3 inches to either side of the YELLOW circle is the LIGHT spot of the tire. Each
tire is confirmed at the factory for radial balance, and marked at this point. For most mounting
practices, Sumitomo suggests mounting this YELLOW circle near the valve stem, and use of
industry recommended procedures for safe tire mounting.
Red – A RED circle denotes a measurement of high-speed run out (measurement called
HARMONIC). If the wheel/rim is an OE spec rim, it is marked at the factory with a DIMPLE (in
the rim/wheel heel). If this tire/rim assembly gives a vibration at high speed with the YELLOW
circle at the valve stem and the bead is checked for proper seating, then the RED circle should
be matched with the DIMPLE.
In Yokohama's case, the situation is the same. They include a uniformity marking and a weight marking:
https://www.yokohamatire.com/tires-101/advanced-information/match-mounting
Quote:
When performing weight match-mounting, the yellow mark on the tire, indicating the point of lightest weight, should be aligned with the valve stem on the wheel assembly, which represents the heaviest weight point of the wheel assembly. After match-mounting by either of the above methods, the tire/wheel assembly can be balanced.
