Originally Posted By: spackard
The Arcan 3 ton jack from Costco is a penny under $100; S&H is $5. Weight is 58 lbs.
A few years back I bought their XL35R, an all-steel one. It's a bit heavy
at 100 lbs. I'd get the above one if I had it to do over again.
The larger wheels spread the load onto my old driveway better, so I get fewer jack tracks on the old concrete driveway, and the wheels get less deformed from the tiny rocks standing proud of the concrete base.
Also, sometimes I want to pull the vehicle sideways a bit once it's on a jack. A lot easier to do it with the wider wheels on the XL35R.
Trying to reposition a vehicle that's on a jack, using the wheels of the jack, sounds hairy as [censored].
