i do my own tire checking,most tire shops have gauges that are in accurate
However,the tire pressure number to follow is not on the door but on the tire itself
and thats just a MAX number
Most tires that say for instance 44PSI seem to like 38-40 best for wear and ride comfort
I rotate every oil change and watch tire wear,too much on the edges and it needs
more air or too much wear in the center of the tread and it needs less air.
I am looking for even wear so my tires last max miles
