Update time: I've been slowly working on this when I have time, trying to get it ready to drive before the snow flies. I'll admit this truck needed more work than I initially realized. But, I've been having fun fixing it up and I'm committed at this point. Even after all this work, I'm still only about $800 into it so far. I hereby name this truck the Junkyard Refugee, since it was destined for the junkyard before I agreed to take it home, and maybe should've gone there afterall
So far I have replaced: radiator, lower hose, fresh coolant
Rear ABS sensor (another freebie I had laying around the garage)
Passenger side upper control arm (bad ball joint)
both rear parking brake cables
parking brake shoes and hardware
brake line on rear axle
Still on the to-do list:
Reinstall diff cover and fill with fresh fluid. (replacing the parking brake shoes is MUCH easier without the axle shafts in the way)
Bleed the brakes/do a full brake fluid flush and finish reassembling the rear brakes
Replace coolant temp sensor (gauge on dash doesn't work)
Fix the exhaust leak right where the passenger side manifold bolts to the Y pipe. It's throwing the o2 sensor off and making the computer throw a lean code. It won't pass emissions with that code, so I need to fix that before getting it registered. I bought an oxy-propane torch to help me get the bolts loose.
Replace the spark plugs
Get 2 new tires and get an alignment done.
Drop the transmission pan and do a fluid/filter change and see what's making the trans shift funny. I'll try to limp it along for this winter, then get it rebuilt in the spring if I have to.
And finally, install the new front seats I just scored today. This Explorer has side-impact airbags built into the front seats, which was a fairly uncommon option during these years. A previous owner replaced the driver's seat for some unknown reason, and the replacement seat does not have an airbag. So the airbag light on the dash is always on and blinking. So I started searching for another seat that does have an airbag to fix it. After searching all over the internet and realizing that seats with airbags are pretty rare, I almost gave up hope. Then I went to my local pull-it-yourself junkyard yesterday. They said they weren't showing anything on their inventory (I already checked online and knew that) but they said they might have an Explorer with seats that aren't on the inventory. The yard was already closed for the day, so I came back this morning and searched through the yard. At the back corner of the lot, I found a 2nd gen Explorer. My heart fluttered at the sight of it. I checked it out, and the seats did not have airbags. Darn. Then I spotted a Mountaineer a few cars over. I look through the window and it had very nice leather seats. Could it be...? Yes! They have airbags!
They are also power adjustable seats, which my Explorer doesn't have, but it shouldn't be hard to wire them up. I had to move the seat up to access the rear bolts, and since they're power, I needed to have a battery hooked up. I didn't bring a battery. But there just happened to be a battery sitting in the back seat! I think God really wanted me to have these seats
. I hooked up the battery and I was able to move the seats and unbolt them. I originally just wanted a driver's seat, but I figured I might as well grab the passenger side too and have them match. These seats are in pristine condition! I hauled them back to the front desk. $50 each. Sold! I think going to the junkyard is my new favorite hobby. I had a lot of fun hunting down my parts and was super excited to find them. I might go back this weekend and see what else I can find.
