So high pressure grease fittings are Zerks. But there seem to be low pressure fitting that look like about a 1/4" bump, round on top with a hole in it... I take it there is some kind of greaser with a plastic cup end that will just push grease into these?
Please name the fittings and what do I use to apply grease?
Some of these look to be cast right in to various components and just drilled as part of the build ...
